Dynamic scale bar
Dynamic scale bar
Message 1 of 14
Dynamic scale bar
Hello,?Does anyone happen to have a dynamic imperial architectural scale bar that I can use in a drawing I created in autocad civil 3d 2012?
Replies (13)
Message 2 of 14
imadHabash
HI,
>> ..to have a dynamic imperial architectural scale bar that I can use..<<
you can found it in AUtoCAD in the Tool Pallets (Ctrl+3) see attached image
Good Luck..
Imad Habash
Message 3 of 14
@imadHabash wrote:
HI,
Good Luck..
Thank you for your response but what I am looking for is a imperial dynamic scale bar that has the following scales 1"=1', 1/2"=1', 1/8"=1', 3/32"=1', 3/16"=1', 3/4"=1',1 1/2"=1', 3"=1', 16"=1',
Would you happen to have one that I can use?
Message 4 of 14
Emmsleys
Following up on your thread, it appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 5 of 14
try inserting this at the scale of the drawing. 48 for 1/4"-1'-0"
Message 6 of 14
senji056
I have the same issue. The scale bar menu doesn't have the architectural scales such as 1\8=1'-0"  , ... 1/32"=1'-0" and so one.  Can someone help please?
Message 7 of 14
vinodkl
Try the attached graphic scale(see attachment)
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 8 of 14
senji056
Thank you very much.  All I needed
Message 9 of 14
senji056
Accept
Message 10 of 14
timothy_crouse
Nice Scale
Message 11 of 14
Hello.  I would like our company to start using the dynamic imperial scale that was pictured in this thread.  I noticed 1"=40' is missing.  Is there a way to add scales?  I can't figure that part out.  thanks in advance.
Message 12 of 14
h_s_walker
The block has multiple visibility states for the different scales. You need to add a new visibility state and some new text for the new distances
Howard Walker
Left Handed and Proud
Message 13 of 14
wendi_burgin
How do I add a new visibility state (basically another scale choice) to an existing dynamic block?
Message 14 of 14
timothy_crouse
In the block editor
On the ribbon tap the pane to bring up the visstate manager
tap NEW
Turn off any objects, r-click > object visibility > off for current state
drop your new scale into that view.
save and exit the block editor
Thats the general idea
-Tim C.
