Dynamic input to change the number of items in a fixed distance
crdlgrd
Observer Observer
crdlgrd
Observer
Observer
Dynamic input to change the number of items in a fixed distance, for example  (in a 6meter box, i want to be able to change the number of circles inside it)
 @crdlgrd The title of this post was modified to increase findability, by CGBenner.
h_s_walker
Is it only 2, 3 or 4?
If it is I would use visibility states and if the rectangle needs to stretch I would use move actions with multipliers on the circles to keep them equidistant
Howard Walker
Left Handed and Proud
K_Kubat
Create an axis line
Create an array on a path using AutoCAD
Set it to Split
In the Parameter Manager, create a new parameter named "Count" and enter 2 as the value.
Select the array and enter "Count" for Elements.
Select the auxiliary axis and convert it using Manage Construction.
Exit the Block Editor by clicking Save.
In the properties window you can now change the number
