DYNAMIC ELEVATION STEP DOWN.
gddraftingllc
gddraftingllc
Hello, im in need of some help on this dynamic block. After trial and error i still cannot get it to do what i want. im trying to make a step down marker for places like doors and elevator pits etc. i have the block mostly done the way i want but the text is giving me issues.
Block summary: step down that stretches from 3" down to 12" (for now).attribute that i can edit to show elevation change for example -4". rotate the whole thing with 45 degree intervals for different sides of the house. keep text attached to line that represents floor being stepped down to and rotate it with the whole thing all while keeping the text at up and down direction. if that makes sense. see what i have so far. thanks
gddraftingllc
***UPDATE: I GOT THIS FAR. CAN ANYONE MAKE IT BETTER??
vinodkl
Hello @gddraftingllc
Can you please tell me if you are looking for something like this? See attachment.
Please use the command "REGEN" to update the value in the attribute automatically.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
rosie_lucas1
Hello @gddraftingllc!
Welcome to the community! Did the information provided by vinodkl help? If this fixes the issue, please go ahead and accept it as the solution. This helps other users benefit from the information. In case you still need help, please provide an update here so we can help you best moving forward.
Thank you!
Rosie | Community Manager
gddraftingllc
This is awesome thank you!
