Dynamic door block - incorrect "SCALE" action using "STRETCH" action.
MichalHakel_SP
MichalHakel_SP
Please could someone help me with "SCALE" action in my dynamic door block ?
When I try to stretch my "door width" with "SCALE" action reffered to that, my "door arc" is moving incorrect Up/Down a little bit.
I am sending video to represent my problem and also .dwg file with dynamic door block.
Thank you very much guys for your help in advance.
j.palmeL29YX
>>Here<< a suggestion how to repair the scale problem.
I think also the rotate parameter/action need your further attention. (I can't believe you want it works as it currently does).
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Jürgen Palme
MichalHakel_SP
Thank you very much " j.palmeL29YX". It works 🙂
