Dynamic Blocks Forum
Dynamic Dimensions?
7 REPLIES 7
Message 1 of 8
348 Views, 7 Replies
Dynamic Dimensions?
Currently struggling to set up a block using dynamic parameters and dimensions - parametric constraints need to be based on dimensions, but my dimensions are supposed to be variable based on my grips and actions, and AutoCAD freaks out when I try to define a parametric constraint based on a non-locked parameter. Any advice? Thanks.
Labels (1)
7 REPLIES 7
Message 2 of 8
In case my post was unclear, this is an article ostensibly getting into what I want to do. Also, I'm still recovering from a surgery and my brain is very foggy atm so if this is complete nonsense I apologize.
https://knowledge.autodesk.com/support/autocad-raster-design/learn-explore/caas/video/youtube/lesson...
Message 3 of 8
pendean
Thanks for the link: that is spcifically for RASTER DEISGN, an AutoCAD add-on. Are you using RD?
The post is also a topic on constraints, not "dynamic dimensions": that is a separate ability best explored in HELP starting right here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Message 4 of 8
in reply to: pendean
I am not using RD, thanks for letting me know. I have looked at the other resource you sent me, however, and I think I understand it pretty well - I'm just struggling to create a length parameter that can be manipulated using a stretch grip while still being able to be referenced by other parameters. Do you have any idea how I could go about doing that?
Message 5 of 8
pendean
Show your work: post your DWG file with your content, add notes explaining what the final result is desired.
Message 6 of 8
In this Dynamos drawing there's a block called "Insertable" - it has three "dials" on the bottom with grips that alter the shape of the geometry at the top. Grips one and two change the width and height of the geometry, while the third grip is supposed to alter the height of a "toe kick" rectangle within the geometry. It should end up being d1 - d3 units from the top of the geometry, d1 being the result of the 1st dial and d3 being the result of the 3rd.
Message 7 of 8
j.palmeL29YX
If I guess right it should be possible.
But for clarifying before:
Please show us a (manually drawn) example how the geometry should look after dragging the third grip. Where/what are d1 and d3?
Jürgen Palme
Message 8 of 8
j.palmeL29YX
in reply to: j.palmeL29YX
Following exact your instruction I would suggest a block as attached:
d1 drives the width of the outer rectangle
d2 drives the height of the outer rectangle
d3 (with d1) are used to drive the height of the inner rectangle the height must be the difference d1-d3.
But I'm rather sure this is not what you want to achieve, or ... (?)
We need a more precise explanation or an example as I already asked above.
Jürgen Palme
Autodesk Customer Advisory Groups
”Boost
