Dynamic circle - increase size using diameter, not radius
thomas
thomas
I have a dynamic circle, when you select the grip it shows the radius which you can type in a new dimension.
Is there a way to make the circle scale up from its center and be able to type in a diameter instead radius?
pendean
Community Legend
Community Legend
Umm... You do know that a regular CIRCLE object does that "dynamic" thing when you just grip a quadrant, right?
Especially since your block does not appear to do much else in a special way like set increments etc.
thomas
Yes but I eventually want to add in more detail to this block and scale all the linework together - these are for restaurant tables. I'm just starting with a circle to see if it works
Libbya
It is useful at times and easy to do.  See screencast:
Alexander.SanchezVBJ2Z
Exactly what I was looking for, and great illustration btw. Thank you!
