dynamic blocks
dynamic blocks
falconbird
Message 1 of 10
dynamic blocks
falconbird
I been trying to create a steel angle dynamic block using a table. Can someone help me with completing this drawing. I have attached a steel angle dynamic block. Please tell me what I am doing wrong. Thank you.
Replies (9)
Message 2 of 10
Libbya
Double deja vu...    https://forums.autodesk.com/t5/dynamic-blocks/dynamci-blocks-with-steel-angle-shapes/m-p/6047239/hig...
I'd say the biggest issue is that you are using parametric constraints rather than dynamic parameters/actions.  It can be done with either, but constraints are much harder to get to behave properly.
Message 3 of 10
Libbya
I have to say I feel a bit put off by the fact that you asked the EXACT SAME QUESTION previously, I spent a CONSIDERABLE amount of time trying to help you at that point in time.  Why didn't you use the step-by-step screencast that was already provided?  Instead, you want the entire explanation all over again?  That type of behavior really dampens my enthusiasm for helping.
Message 4 of 10
falconbird
Libbya,
I am sorry if this put a damper on your day but I am trying to solve a problem here not be lectured. Thank you for your precious time.
Message 5 of 10
Libbya
Why don't you use the screencast that I posted in the linked thread?  It shows you exactly how to do what you are asking... which is exactly what you asked before in that thread.
You may not understand that the people offering assistance here are not paid for their efforts.  It is offered purely out of the kindness of their hearts and at no insignificant expense in time and effort.  To consider that time as worthless and ask the EXACT SAME question after considerable effort was taken to give you the precise answer previously is a very inconsiderate and obnoxious thing to do.  When you take that type of action, it seems clear to me that you need a lecture about basic courtesy far more than you need any assistance with AutoCAD.
To be clear your inconsideration does not 'put a damper on my day'.  My day is fine either way.  What it does is remove the desire to assist you with your AutoCAD issues.
As far as finding the solution to your problem is concerned, it has already been provided in exacting detail.  Avail yourself of the assistance that has already been offered.
Message 6 of 10
pendean
Community Legend
Community Legend
Friend, click on this link and watch the video, it is what we believe you are looking for https://forums.autodesk.com/t5/dynamic-blocks/dynamci-blocks-with-steel-angle-shapes/m-p/6047239/hig...
Otherwise let us know why this was not the answer if you previous watched it fully, and explain in detail what did not work.
Message 7 of 10
falconbird
pendean,
Thank you for being polite and patient.
Message 8 of 10
Hi Falconbird,
I think you want to result per my attached dynamic block. I have completed you block based on the question you asked.
Message 9 of 10
serkancavuslar
Serkan ÇAVUŞLAR
CplCAD / Türkiye
Message 10 of 10
awesome block, thank you!
