Insert Block into Table
I would like to insert a dynamic block into an acad table with specific different visibility state.
Is this possible, I don't see an option in the properties of the table cell.?
I would like to use this for blocks that are used for legends.
JL
pendean
Community Legend
Community Legend
There is no option to do that within TABLE cells: you will have to "float" the dynblock over the cell and keep track of it's location, or create a set of static blocks just for this unique purpose.
In order to insert a block into a table, you right click the cell and hover over "Insert." You'll see the option "Block." This will allow you to put a non-annotative block into the table cell. If you have a symbol that is annotative, what I do is in model space, I type "block" for a command, then I resave the block I have already created with a new name and make sure that I unclick "annotative." I hope that helps!
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
I have recently encountered the problem with insertion of annotative blocks.  Although you have suggested a good workaround, I would be happy if AutoCAD would develop a permanent solution.  I'll be using your method until they do.  Thank you.
