dynamic blocks
dynamic blocks
dynamic blocks
applied stretch option to dynamic block but when i apply the rotate option the rectangle revolves around a different axis and changes shape - any ideas please
Libbya
If you post the block and use capitalization/punctuation I'll try to help.
ojuris
but I thought that you are magician  🙂
Charles_Shade
Welcome to the Autodesk Forums!
As has been asked: Post your block and I expect a solution will be forthcoming.
Try this: Remove the Rotation Parameter and if need be the Rotate Action from the Stretch Action selection set.
