The attached drawing contains the block UPE, showing the standard steel profile with that name.
The different sizes are controlled by a number of dynamic parameters and actions, and the parameters are controlled by a block table. This was a little of an experiment, but apparently the question if you can use a combination of a block table and dynamic parameters is yes.
The block has visibility states that allow the profile to appear as contour, as contour with different hatch patterns or as hidden line.
This also seems to work right, but with one exception: The Solid hatch is not updating when the size of the profile is changed. After the latest edits it simply disappears. What could be the reason for that?
Thanks in advance for any help on this.
