Dynamic blocks
Dynamic blocks
Dynamic blocks
I have used a chained polar parameter and use a polar stretch to 'rotate only' the arc.
eventhough arc's one of the end is extend with proportional to adjusting length
I have attached the file below. also adding flip parameter's ,after two or more flips arc moving weiredly.
akhtar4223
Use standard dynamic block already available in tool palette.
j.palmeL29YX
You can repair your block definition >>this way<<
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
Thanks for the help
