- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey All,
Something I cannot figure out.
Can we make a visibility in a DY-Block to be dependant to the other? What I mean?
See Block attached. It has 2 Visibilities. One changes the shape, the other changes the letter. We shall not have Circle-A for a reason so it is not included in all visibilities. You can have Square A or B or Circle B.
Issue:
You cannot Change the shape to a circle if letter is A. To do so, you must first change the letter, then change the shape.
What I want:
Make it possible to change the shape to a circle even if letter is A, but letter to change to B automatically. That's what I call being dependant.
You may notice there is a base point and a flip as well. I like to keep them in the block. Because in the real block which this concept is used in it, I must have a base point so it flips. If this is not possible, I will find a way around it. In another block, the existance of a base point out of 0,0 was creating issues.
For now, Please see if you can make Visibility of letters to be dependant on Visibility of shape.
I appreciate your help.
Cheers,
Behzad
