Dynamic Blocks Showcase: Share Your Favorite Dynamic Blocks
Victoria.Studley
Autodesk Autodesk
Message 1 of 313
Victoria.Studley
Dynamic Blocks Showcase: share your favorite dynamic blocks and show us how you made them!
As a follow up to our latest dynamic blocks webinar, we'll post our favorite dynamic blocks here with Screencasts to illustrate how we created them.
Please join the conversation: share your own blocks or get some inspiration from your fellow community members. Let us know how you save time in your designs by using dynamic blocks!
If you're interested in watching our Dynamic Blocks webinars, or signing up for future AutoCAD webinars, check out these links:
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Replies (312)
Message 161 of 313
tim_crouse
There is a nuisance operation to the RAF - Universal 1 & 2 Row Block.
You will have to set the trimmed end length prior to arraying the entire row otherwise the stretch function does not operate as intended.  I can only assume this is due to the array / move operation inside the block.  When the end of the block with the stretch function is moved the stretch "selection window" does not appear to be moving with the control.
If someone knows a better way to handle this please let me know and I will update the block.
Best Regards
-Tim C.
Message 162 of 313
Here I found some nice dynamic blocks to download: https://cad-blocks.online/
Message 163 of 313
tim_crouse
Here is an APC NetBotz 250 with adjustable enclosure brackets which are useful for many enclosures.
Best Regards
-Tim C.
Message 164 of 313
hi guys,
If anyone like to have Dynamic Block For Piping PM me or Send me a Mail [email protected]
Master From Lost Nalanda
Message 165 of 313
tim_crouse
Here are a bus duct known by the trade name of DATA BAR mfg by Anord Madix, Richmond Virginia
These are the only computer room type bus duct I have found that carry a seismic rating stamp.  PDI and Star Line generally require a waiver on projects where the material is to carry a seismic rating.
Hope a few folks find these useful.
Best Regards
-Tim C.
Message 166 of 313
tim_crouse
I saw the concept of the elevation marker that provided the elevation value in an attribute as it was placed into the drawing.  I thought it would be useful to me as well as other folks.
I cleaned up the concept a bit a provided it here.
Best Regards
-Tim C.
Message 167 of 313
Ryan_Lehtonen
It's a good one.  I used something similar when going precast concrete catch basins and culverts to get my elevations and heights correct.  Thanks!
Ryan Lehtonen
AEC Design Technologist
Message 168 of 313
thank you for your responses
Message 169 of 313
cloweRE8TC
This is just a set of scale bars.
Message 170 of 313
tim_crouse
Here is a set of blocks useful for room layouts and details.
Best Regards
-Tim C
Message 171 of 313
matthew_neesley
Here's a VERY dynamic block for conveyor beds that has been evolving for half a year.  Descriptions are in the file...got a lot of help from people at this forum, so thanks to all!
Message 172 of 313
Vincent_CAVUOTO
Bonjour,
Voici ma contribution 😉
I hope you enjoy
Message 173 of 313
Vincent_CAVUOTO
Ceci est un bloc 😉 👉
Message 174 of 313
I hope some of you can have some use with these blocks I made for architectual drafting. The story behind the strange title block is a long one but it came down to us needing an 11X17 page that had the same size seal as the 24X36 so I made a block that can swap back and forth with no issue all you need to do is print at 24X36 and scale it down by 50% when printing the 11X17 version. (and yes I understand 22X34 would have been a better page to use if I was going to scale it by 50 but it was not my choice in the matter)
Message 175 of 313
i wish i had this back when i worked oil & gas. nice work!
Message 176 of 313
tim_crouse
Here are a few details I put together to assist with concrete slab design, comments welcome
Many dynamic blocks inside the details
Tim C.
Message 177 of 313
tim_crouse
Hope some folks find these useful.
The file also includes many other electrical Plan-View Symbols useful in electrical design
Best Regards
-Tim C.
Message 178 of 313
tim_crouse
Here is an update to the Bus Duct Pieces,  again I included them in a file that has many electrical blocks.
Best Regards
-Tim C.
Message 179 of 313
tim_crouse
Here are a few isometric Raised Access Flooring Block
Best REgards
-Tim C.
Message 180 of 313
tim_crouse
Added Wipe Pouts to the Pedestals
-Tim C.
