DYNAMIC BLOCKS: how to keep attributes horizontal while rotating a block?
Message 1 of 58
I found a video with example how attributes moving with block, but remains horizontal. I cant find how to do it. Maybe somone can help me?
https://www.youtube.com/watch?v=0sXzcYqnDsc&list=HL1393395570
Accepted solutions (3)
Replies (57)
Message 21 of 58
Libbya
...or a reason you didn't use the step-by-step screencast I posted that shows how to easily rotate the block and mtext around a point while keeping the mtext horizontal?
Message 22 of 58
lamensterms
I never realised that this was also possible with MTEXT.  Thanks for the tip Libbya.
Message 23 of 58
douglas.shortCM2W5
I had homework due for class tonight and missed your video. It looks awesome tho and I will try and revamp my block with what appears to be the correct way to do this! Thanks so much for taking the time to record and post this. I've learned half a dozen programs for school this past year, but autocad is unparalleled in being unintuitive and perplexing so this sort of step-by-step guide is incredibly valuable. If it goes well, I will share with my class!
Message 24 of 58
I suspect whether it is a text or attribute, it is annotative with the "match text orientation to layout" option ticked.  no special plugin.
Message 25 of 58
Neither method worked for me. (text or mtext attribute) Autocad LT 2015
Message 26 of 58
Libbya
So, you made a block and couldn't manage to keep your text horizontal through a rotation?  Was there some step unclear in the step-by-step screencast I posted on page 1?  The precise details on how to do it have been posted in this thread.  Considering you were not able to follow those directions and did not bother to attach the block you created (so someone could see what step you did not follow), how do you expect that it is possible for anyone to help you?
Message 27 of 58
Created a style as annotation and "match text orientation to layout" option ticked. Used the style to create an attribute defination within a dynamic block. Neither method (text or mtext attribute) worked for me. Autocad LT 2015
Message 28 of 58
h_s_walker
Can you post a drawing with your block in it
Howard Walker
Left Handed and Proud
Message 29 of 58
Libbya, Really enjoyed your condescending attitude. It gives me real confidence in your content. Yes, after several hours of running your video, I was finally able to figure out what you were doing. It was not easy, you move too fast and I have no audio. The text did rotate, but the Created Attribute (text) is not editable with the DDATTE command. You have to edit the block if you need to change the text. (This is the same problem as using a Dimension that is overridden with text. A solution that was given in another post.) As for uploading my block, I am not allowed due to company policy.
Message 30 of 58
Libbya
No need for concern about my attitude.  Your own attitude is what ought to concern you.  You are the one petitioning for free help and also the one putting in a total of zero effort to avail yourself of the help already offered and at the same time putting in zero effort to make it easier for those who might be (might have been) willing to help you.  I will certainly avoid the impulse to ever attempt to help you in any way in the future.
Message 31 of 58
Please, do not offer to help me in the future. I have spent several weeks searching for a solution, and 10 hours on your solution. We are not experts and do require a little help now and then. Your attitude is abismal. Go play in someone's else's sandbox.
Message 32 of 58
The annotative style method doesn't work. Dynamic blocks actions require the selected attributes to have their position locked, which makes the attribute rotate along. The point parameter method does work. You need to "lock position" of the attribute (in properties) for it to work. Also, you need to do it in the sequence described at the beginning of this thread; it might not work if you create the rotation first and then add point parameter object.
Message 33 of 58
Libbya
The order of creating actions and parameters does not affect whether or not they work.  The ability to add items to the selection sets of pre-existing actions works fine.
Message 34 of 58
carlos.watson
Observer
Observer
@Anonymous wrote:
When you use the grip of the rotation parameter the point parameter follows the rotation, by using the "Chain Action" the point parameter follows with the move action when you rotate.
To sum it up: You don't rotate the attribute, you only move it with the rotation angle.
Great how-to man! Clear, concise, short, and easy to follow, with a bonus explanation at the end!
It worked as advertised for me and answered a question I've had for a few days now. You're post from years ago is still helping people learn today :fistbump: 🙂
Thank you so much!
Message 35 of 58
User_2011
The command is: TORIENT
Message 36 of 58
User_2011
try TORIENT
Message 37 of 58
rhgrafix
 What software did you use to add controls to the video?? Is that Screencast? It's very cool.
R.L. Hamm
Message 38 of 58
After hours and hours of trying, I realized that it is best to unlock block attributes..
Message 39 of 58
Libbya
No it is not.  What nonsense.  Hours?  Seriously?  What were you doing in those hours?  Locked = yes allows attributes to be acted on by dynamic parameters/actions.  Locked = no does not.  It is very easy to get attributes to stay horizontal while being rotated if locked=yes, and impossible if locked=no.
Message 40 of 58
I'm learning Autocad and it's not something really easy to learn.
