Dynamic Blocks Arcs
Dynamic Blocks Arcs
Dynamic Blocks Arcs
I want to create a dynamic block for our sub detail marker we use.   This marker consists of 80% of a circle as a arc that has two arrows at the end points and it has a letter in the middle.  The only thing we change on it the letter and we drag the mid point out to make the area its hows larger or smaller.  I have it converted as a block with a attribute which takes care changing the letter.  I have tried stretches, scaling, radius constrain, and several other constraints to try and keep the arc end points attached to the arrows with changing the arrows sizes and text size.  Everything I have tried either broke the arrow shapes or had the arc endpoints no longer attached to the arrows.  I was hoping someone knew of a way to adjust the arc as a dynamic block like you can before it was a block.
I figured out how to get the block to do what I wanted.  I was missing fixed location constrains with my coincide constrains locked the ends points so when the radius changed it mimicked the same result of changing the mid point.
