- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently an intern with around a month's worth of experience with autocad. I have been given the task to create a dynamic block with a lookup table that will allow someone to change the sizes of the block. I have looked around these forums for some clues, but I have not been able to fully put everything together. There is a perfect example in the lookup actions area in Autocad's user guide, but it is pretty vague to me. I am using 2011 Version of autocad, I was hoping that someone could help explain how to do this a little more clearly. I have attached a file with the boxes I am attempting to cut down to one using a dynamic box. Also I am wondering if I would be able to keep the triangle/text/number relatively in the same areas they are now; is this possible?
Lee
