Message 1 of 19
06:12 AM
Attached are Cable Ladder Rack Dynamic Blocks with several Visibility states and a flip and rotate parameter. The blocks are only 147kbs and 167kbs but when I insert them into a design layout the file becomes @Anonymous,000kb. I have 230 instances of the "BOM-600mm Radius" and 512 instances of the "BOM-Non-Radius" blocks in my design Things I have read and tried to reduce this size include the following
- Scalelist edit - only 2 scales 1:1 and 1:100
- -purge, Regapps - nothing
- The mindblowing test is that when I deleted several Visibility states the block size actually got bigger
- The functionality of these blocks is great but file size is a huge issue
Anyone can troubleshoot the issue and provide a solution
