Dynamic block with stretch and array
zbysogi
zbysogi
Hi.
I am trying to make a stretchable block with array action BUT as the bigger box is 2900 in hight the little box inside that I need to put in array of 800 is suppossed to correspond with the hight.
For example:
If the hight is 2900 I want only 1 box inside
then for 3700 (800 more) I want 2 boxes inside spaced 800 from each other.
What am I struggling with is the little box fills up the big one with 3pieces because 3 of them spaced in 800 fit into 2900 and I want them to start building up from 2900 up. Like that:
2900 - 1box
3700 - 2 boxes
4500 - 3 boxes etc
I tried doing it with lookup but that didnt work. Is there any way of making it work?
Can someone help please?
j.palmeL29YX
Try the attached suggestion.
Jürgen Palme
zbysogi
Awesome, thank You!
zbysogi
EDIT:
delete post
j.palmeL29YX
>>Click<<
HTH
[EDIT]: Oops, in the meantime you found it yourself?
Jürgen Palme
zbysogi
Yeah. I was missing the chain action feature of the array parameter in the props. Thank You!!
