When creating a linear array the first/last array element never shows
gsoutherlandHSC9D
Observer Observer
gsoutherlandHSC9D
Observer
Observer
My dynamic block has a linear parameter and then a stretch action for the encasing square and an array action for the lines on the inside to replicate. The increment is 25, the minimum is 25 and the maximum is 1000. For some reason the very last array element never shows.
Here are some pictures of my issue:
Libbya
The first new arrayed object appears when the associated parameter is equal to 2X the array column offset.  The second new arrayed object appears when the associated parameter is equal to 3X the array column offset.  Etc...  Adjust the as-drawn associated parameter so that it is the appropriate size to accommodate those new objects appearing where you want them.  Often, making the associated parameter chained, setting grips to 0 and stretching it with a second parameter is required to get everything to behave in a desirable way.  Post your block file (not pics) if you need more assistance.
