Dynamic block with parameters and a text with attributes
Delinear
Delinear
Good morning, I have created this dynamic block with parameters and a text with attributes that reads the value of the parameter and divides it by 1/3, the problem is that I do not round the value and I do not know if there is any system variable to solve this problem.
I would like to know if there is any variable or some other method to make this block.
I attach the block
1.jpgthank you.
guar571225
If I got your question right what you may be looking for is at http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-DBFA3E85-2055-4698-85FD-6B30D39F3FA4
The function round is very primitive because it does not allows for the selection of N decimals, so you must use the Trunc one, as in Trunc(1000 * L_DCHA*1/3) / 1000 to get 3 decimals.
Here are some snaps of the page.
h_s_walker
ROUND (984/25)*25
This rounds 984 to the nearest 25. So your field would be ROUND(YOUR VALUE/3)
See the image below. The distance you're looking for is the one labelled L.
Howard Walker
Left Handed and Proud
