dynamic options disappear when brought from another .DWG
morganism3
morganism3
So, I had a DWG that had a bunch of blocks called photo_det as blocks representing smoke detectors. Let's call this dwg A. The smoke detecotr symbols in dwg A didn't match the symbols I was using in "dwg B". I needed to put smoke detectors matching my company's symbol in the same locations on a different file. So rather than doing the same work twice, I took "dwg A" and did RENAME and changed photo_det to SMOKE DETECTORS, knowing that when I copied them into "file B" that the blocks would take the appearance of the preexisting SMOKE DETECTORS blocks in file B.
It worked fine, but I was surprised that the copied smoke detectors from dwg A don't have a dynamic drop down for visibility states like the smoke detectors I had already made in dwg B. Why didn't they pick up this aspect of the block?
Also, the basepoint moved, but I hear that has to do with whether it is set as fixed or not.
I took out all identifying info and left what remained of the blocks, if you need to see them.
h_s_walker
It's because your X Y and Z scales of the block are different.
Make the block scale uniformly and the dynamic properties will reappear once the scale is sorted.
See the attached drawing
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
Your destination file already had a block with the same exact identical name in it, butt different parts: RENAME command in the destination file should take care of it, just change the name.
