Usiing array and linear Parameter
Hi
I need a Dynamic Block Solution for the Attached Snap Buttons
Where my input will be number of Button!
And it should arrange in Column and rows as specified Please try to eliminate or Avoid Visibility feature
Thanks in advance
ojuris
try this
Thanks could you please explain it
ojuris
when you open block you can see 3 circles (all in same place)
for 1. circle is linear parameter "1" with "Array" action to create first column
for 2. circle is linear parameter "2" with "Array1" action to create column and linear parameter "22" with "Move" action to move the circle (all column) to left in right place
for 3. circle is linear parameter "3" with "Array1" action to create column and linear parameter "32" with "Move" action to move the circle (all column) to left in right place
After that Block properties table with needed values for all parameters in each state
