Dynamic Blocks Forum
Dynamic block with MText instead of Attribute
5 REPLIES 5
id_11
497 Views, 5 Replies
I was wondering if it's possible to have a dynamic block with MText that is edited instead of an Attribute.
The reason is that I need to have a subscript/superscript, which I think is not possible with Attributes. I could be wrong though.
Tags (1)
Labels (1)
5 REPLIES 5
hwalker
in reply to: id_11
You can have MTEXT as an attribute in a dynamic block. See the drawing below for an example
Howard Walker
Left Handed and Proud
id_11
in reply to: id_11
Great thanks, that does work.
id_11
in reply to: id_11
Sorry but I thought that after getting Multi Line Text that I could stack for subscript or superscript.
But it's not available in the text formatting options.
I may have read about a shortcut key last year but couldn't find it doing a web search this time.
hwalker
in reply to: id_11
Depending on which toolbar is showing you need to select the text you wish to superscript/subscript and then click on the one of the icons ringed in the image below. Sorry forgot to mention also at the command line type ATTIPE and make sure the value is 1
Howard Walker
id_11
in reply to: id_11
Thanks for clarifying. It works now.
Forma Design Contest
AutoCAD Beta
