Dynamic block with look up table and stretching problem
Hi!
I made a door block with look up tables and a stretching option. The look up with the visibility drop down menus work fine, but as soon as I use the stretch option it reset all the visibility options, and sometimes a 'Converted' option appears in the drop-down menu. Does anyone know how to fix it?
steven-g
You need to take a good look at which actions and parameters are included in all the different visibility states, at the moment they aren't very consistent, and there are just too many variations to point out just one thing that is causing problems. But as an example your stretch action is only shown in the first visibility state. It will help if you make 'bactionbarmode=0' then you can see the actions (lightening bolts).
Libbya
Position 1 and Position 2 are used to the values of the different selections.  They are currently included in the Stretch action's selection set.  Because of this, when the stretch action is used, the position values are changed and no longer correct for the lookups or double lookup.  Remove them from the Stretch action's selection set.
