I am trying to set constraints to this block and having some issues. I want to constrain the attribute text so when I stretch the block from the grips the text centers itself automatically within itself. The constraints will not let me pick the grip on the attribute text as a point. What am I missing?
Scott
Solved by Charles_Shade. Go to Solution.
Welcome to the Autodesk Forums!
Well for one thing post the Block and not a picture so we can see what you are doing.
I would not use Constraints for what it looks like you are trying to achieve here.
Three Stretch Actions and Two Parameters along with Three Move Actions and Multipliers of .5 would work well.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Using a Linear Parameter - set a move action with a distance multiplier of 0.5 from the object property window. Works like a charm everytime.
