- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone, first time posting in the forum.
I have a dynamic block that has been distributed around an area using its different visibility options. Now, I need to transform the dynamic blocks into individual blocks keeping their visibility (not sure if this is clear).
For example, the dynamic block has visibility A, B and C. I used each visibility on points 1, 2 and 3 respectively. Now, I need to transform the dynamic block in point 1 to an individual block called A, the dynamic block in point 2 to an individual block called B and the dynamic block in point 3 to an individual block called C.
I know I can EXPLODE the dynamic blocks but then I would need to go 1 by one to make then blocks again. If I have 100 blocks it may take a long time.
I also have a lisp to split a dynamic block into its different visibility options. It may be helpful at the start of the project before locating all the blocks, but in my case all the blocks are already in place. Also, not sure if I can share the code here (I found it on the internet), I believe it just need to be modified to make it work as I need but I am not an expert on coding.
Thanks in advance for any comments.
