Message 1 of 8
02:56 AM
Hello community,
I am making a dynamic block of some perfo grating for stairs and steps.
The distance between the holes and the size of the holes don't change in size, but when i add a array function for the grating, it leaves a big gap between the outer edge(see text in block).
I want to fill this hole up with one row of the holes, without changing the distance between the holes.
Because you can't attach 2 arrays to one object, i don't know any other solution.
Is it possible to make this happen using parameters and actions?
Thank you for your time
