dynamic block - rotate multiple objects
Is there a way to set this block up so that once I adjust the rotation on the first antenna the others follow?
WarrenGeissler
You need to add a separate ACTION for each antenna and set the BASE TYPE to INDEPENDENT - then set the base X and Y to the base point of each antenna. You can see an example here:
https://forums.autodesk.com/t5/dynamic-blocks-forum/dependent-and-independent-base-point-for-rotatio...
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Took me a few to figure out what you were saying but it works!
