Dynamic Block Properties
sneha.sadaphal
Message 1 of 9
sneha.sadaphal
How can we change the custom properties of dynamic block after constraint are applied?
Is their any work around to change the property values?
Replies (8)
Message 2 of 9
j.palmeL29YX
Please post an example dwg what you have and tell us what you want to do (or to achieve).
Jürgen Palme
Message 3 of 9
Libbya
Select the block and either adjust the grips or change the parameter values in Properties under Custom Properties.
Message 4 of 9
sneha.sadaphal
Please refer above image for reference
Highlighted is a dynamic block which contains below properties/parameters
if I apply the constraint then it is showing the message
and also not able to modify the parameter as shown in below image
like not able to flip/ not able to change line show.. property
need some solution for this
Message 5 of 9
Libbya
Applying any constraints externally to a dynamic block disables all of the dynamic properties of the block.  That's just the way it is.  Don't apply external constraints to the block if you want the dynamic properties to be functional.
Message 6 of 9
sneha.sadaphal
can I do that by using Jig?
Message 7 of 9
j.palmeL29YX
Hmm, what is "Jig"? (Excuse my ignorance)
As asked above, post a dwg please and let us know more about the needed "functionality" (which geometry do you whish to chance dynamically?) of the block.
Jürgen Palme
Message 8 of 9
sneha.sadaphal
Actually, I am placing the dynamic block by using AutoCAD api (c#).
I can be able to place the block properly at particular location.
but I am not able to constraint
let's consider if I move one rectangle from one location to another location according to the movement the dynamic block should vary
Message 9 of 9
j.palmeL29YX
Unfortunately I only can guess if >>that<< could meet your goal (?). I still don't yet know what you really want to achieve. Where do you have which constraints, what do you (think to) need constraints for, ...?
Jürgen Palme
