dynamic block move action selection
Filipe_Cuango
Message 1 of 27
Filipe_Cuango
Hello guys. I would like to receive your assistance. I want to move the action selection box along with its items with the move command.
And if possible I would like to know what is the variable to make the same action selection box visible?
I appreciate all your efforts.
Attachment image
Replies (26)
Message 21 of 27
barbara3YB93
Thanks!
I tested it with a simple drawing like on your last video and had no problems.
I'm starting to think it's a bug, I tested it on the same block several times and it actually worked sometimes if I fiddled with it on the model not in the block editor.
Message 22 of 27
j.palmeL29YX
@barbara3YB93 wrote:
... it actually worked sometimes if I fiddled with it on the model not in the block editor.
I don't understand what you mean (I only can see that it sometimes works well and somtimes it does not, both on testblock in the block editor).
I can not rebuild this behavior here with my own test models - and without knowing your dwg I see no way to fiddle out what is going on at your side  😞
Jürgen Palme
Message 23 of 27
i_hart6Q2LP
I can't believe I had to scroll down this far to find the answer. Thankyou.
Message 24 of 27
Libbya
I think I must be misunderstanding your post.  It reads like a complaint and that you feel that the free information donated by others is in some way too inconvenient for you.  That can't possibly be what you mean.  Please elaborate.
Message 25 of 27
i_hart6Q2LP
Wasn’t trying to offend anyone. I'm just surprised it took that much digging to find the answer, that’s all. The info was helpful and I appreciate everyone who contributed, and at no point did i bash any of the information provided or dismiss anyone's efforts.
That said, it’s kind of wild to get this bent out of shape over a stranger's passing comment on an AutoCAD forum. I think you're looking into it a bit too much. I hope you're doing okay.
Message 26 of 27
Libbya
I didn't get at all 'bent out of shape'.  No need or cause for your emotional displacement.  Your comments in that regard are nonsense that rival the entitlement in your prior post.  Yes, I'm doing fine, thanks.
Message 27 of 27
j.palmeL29YX
Everybody stay cool and stop it. I think it's a misunderstanding on both sides that's not worth continuing.
Shake hands and make peace. Period and fine.
Jürgen Palme
