Hi all,
I've created a dynamic block with a setback that I can drag/stretch in the x-direction. However, I've noticed that when the stretch is set to 0, the block shifts slightly in the y-direction (from 10cm to 9.9cm). Does anyone know why this is happening?
I've attached a screenshot and the block itself for reference.
Thanks in advance for any help!
Solved by j.palmeL29YX. Go to Solution.
The left definition point of the setback parameter is placed wrong.
You should drag it exactly to the endpoint of the line.
Jürgen Palme
BTW: I'm not sure what you want to achieve but I think you shold remove the Distance1 parameter from the selection set of Stretch2.
Jürgen Palme
Hi Jürgen,
Thank you for the reply! Now it works perfectly 🙂
Ah yes, I was wondering why does the grip of distance 1 also move when I stretch the strech2, now it's clear, thanks for noticing!
