Dynamic block insertion problem
Jonathan3891
Advisor Advisor
Jonathan3891
I recently created these two blocks and everything works fine when you test them. However when you insert them the block objects are way off as well as the dynamic grips.
Its been a while sense I've created dynamic blocks so I'm a little rusty.
Can please someone help me figure out the issue?
Jonathan Norton
Blog | Linkedin
Libbya
The issue is because within the block files, the BASE in model space is not located at 0,0,0.  Open each block file, do not enter block editor when it prompts you, run the BASE command, and set the base at 0,0,0.  Save/close the file.
Jonathan3891
Thank you so much! I was checking BASE but in block editor.
Jonathan Norton
Blog | Linkedin
Jonathan3891
I found one more issue.
If I rotate the dynamic grip counter clock wise, it works fine. But if I rotate it clock wise, this happens...
Jonathan Norton
Blog | Linkedin
Libbya
That happens because you do not have an associative hatch but do not have a single closed polyline as a hatch boundary.  When you rotate to the opening in the circle, the hatch fills into to the circle.  The direction of rotation doesn't matter.  To prevent that create a single closed polyline boundary for the hatch or make the hatch non-associative.
Libbya
I worded my prior reply poorly.  The issue happens because your hatch is associative and the broken circle is part of the boundary.  When you rotate the hatch to the break in the circle, the hatch fills the circle.  Either make the hatch non-associative, or give it a single closed boundary.
