05:35 AM
Hi guys and girls,
Are you able to help me with this one. I need to somehow be able to move my flip function to adjust when the sretch function is inceased or decreased?
If I keep the door the size I've drawn it (900mm wide) the flip function works perfectly. However if I increase or decrease the size using my dynamic block, the flip position stays 450mm from right hand side and doesn't move to the centre of the basepoint.
Is there a way I can stitch the flip line to the baseline? See below snapshot showing my flip line offset from the centre after stretching.
