Dynamic Block Help - How to get the flip function to move with a stretch function
Hi guys and girls,
Are you able to help me with this one. I need to somehow be able to move my flip function to adjust when the sretch function is inceased or decreased?
If I keep the door the size I've drawn it (900mm wide) the flip function works perfectly. However if I increase or decrease the size using my dynamic block, the flip position stays 450mm from right hand side and doesn't move to the centre of the basepoint.
Is there a way I can stitch the flip line to the baseline? See below snapshot showing my flip line offset from the centre after stretching.
maxim_k
Hi @Anonymous
You need to add new Stretch action to Linear parameter for Flip action:
and set multiplier to 0.5
See attached drawing
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
You've smashed it again Maxim thank you!
