Dynamic block for fixed ladder
j_winkleman
j_winkleman
Looking to create a dynamic block for a fixed ladder.  Can get the stringers (sides) to stretch, but am having trouble with the rung spacing.  Would like to stretch the top rung to a certain elevation while the rungs are equally spaced between 12"-14".  Any help will be greatly appreciated.
j.palmeL29YX
In the attached dwg you find an example how to solve such issues. You can adapt it to your needs.
Jürgen Palme
h_s_walker
Do 3 visibility states. 1 for 12", 1 for 13" and 1 for 14", and use a linear array.
If you have drawn your top section at 2" all you need to do is add the whole top section to the stretch.
Howard Walker
Left Handed and Proud
j_winkleman
Appreciate the feedback.  That is close to what I am needing.  What I need is to keep the spacing =>12" and <14", all rungs equally spaced.  Example: if the ladder is 17'-10", I would like the rungs equally spaced at 1'-0 9/16".
j.palmeL29YX
You can not get both in the same block,  >12" and <14".
You must decide if either
you want to be sure, that the distances are always >12" (then can the distance for short lengths of the ladder be > 14)
OR
you want to be sure, that the distances are always <14" (then can the distance for short lengths of the ladder be  <12").
I attached a file with two block variants. If the length of the ladder is too short, can one of the conditions be violated. For greater lengths of the ladder you will fulfill both restrictions, but you will get two different results.
Your choice ...
Jürgen Palme
j.palmeL29YX
BTW: Using these values the first step (from bottom to the top line of the first rung) will be 3 9/16". This seems to me very unergonomic and contradicts stair rules.
Jürgen Palme
j_winkleman
That's it!  The max 14" is exactly what I was looking for.  Thank you!
