Dynamic block flip state
coffeejeanpaul
coffeejeanpaul
Good day.
I have multiple dynamic function set to a crane I am trying to make it flip. The problem I am experiencing atm is when I flip the crane the piston housing stays behind 😕 I tried to flip on the object but that destroys the block entirely, I try to add an additional point to move the object but same result. I am trying to achieve this with out parametric constrains.
Would this be possible ?
Any input would be greatly appreciated.
Libbya
The easiest solution is to move the flip line so that it runs through the bottom point of the polar parameter.  Would that be reasonable?
