The linear stretch pair works like move pair...Is there something wrong with what i'm doing or is it another AutoCAD Bug?
"The linear stretch pair works like move pair..."
"Is there something wrong with what i'm doing or is it another AutoCAD Bug?"
Nobody know that, without to know more about your drawing (I can't see your .DEG)
You can stretch stretchable objects,
are the objects stretchable?
Select one of them, check your properties palette:
Is a LINE? a POLYLINE? What kind of objects is it?
Yan you stretch the object? Command STRETCH
Sebastian
My best guess is that the objects you are trying to stretch aren't stretchable, but that's just a guess and guessing stinks. To answer your question, odds are very high that it is something you are doing wrong, but a bug is also certainly possible (more guessing). Post the block file so we don't need to guess.
I just realized...a dynamic block inside a dynamic block is the cause for the misbehavior. AutoCAD still cant process creation of dynamic blocks using dynamic block... it could well be a useful feature to have in the future.
Thanks.
