Dynamic Blocks Forum
Dynamic Block, Field "value" not updating Attribute "value"
9 REPLIES 9
Message 1 of 10
6831 Views, 9 Replies
I have created a rectangle whose length changes.
The value of the paameter "Dist1" is this length field that I associate to the attribute value. Basically, echo length from Dist1 into the attrib value.
The problem is when I insert the block into the drawing the value is shown as "DIST1", even after regen.
Once I pull the grip point to a new length and regen it still shows "DIST1".
If I go into the ddedit and select the edit box (for multiline data field) the shown value will correct itself, but only one time.
If I change the length again, the dimension does not update.
It worked fine when I tested the block but is having issues days later.
Any suggestions?  thx .j.
9 REPLIES 9
Message 2 of 10
Bob_Zurunkle
Is FIELDEVAL set to 31?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 3 of 10
No sir it was set to zero, let me check this now.
...And there it works now....Thank you very much, kind sir.
thx again for the help.  Would you know where I could find that information, I searched all morning for it on the web but was unable to ferret it out.  Thank you very much.  .j.
Message 4 of 10
rbh1
I found this in the AutoCad Command Reference
To update fields automatically
  1. At the Command prompt, enter fieldeval.
  2. Enter a bitcode that is the sum of any of the following values:
    • 0: Not updated
    • 1: Updated on open
    • 2:Updated on save
    • 4:Updated on plot
    • 8:Updated on use of ETRANSMIT
    • 16: Updated on regeneration
    For example, to update fields only when the file is opened, saved, or plotted, enter 7.
    Type:Integer
    Saved in:Drawing
    Initial value:31
    Controls how fields are updated.
    The setting is stored as a bitcode using the sum of the following values:
    0
    Not updated
    1
    Updated on open
    2
    Updated on save
    4
    Updated on plot
    8
    16
    NoteThe Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable.
    I hope this helps
Message 5 of 10
Charles_Shade
in reply to: rbh1
The summing of the Codes listed in Help is also true of OSMODE and SORTENTS
Any others?
Message 6 of 10
tHIS IS NOT A SOLUTION
Message 7 of 10
timothy_crouse
Can you post the block?
-Tim C.
Message 8 of 10
jsmithAP3Q4
I believe I'm having the same problem, but the FIELDEVAL fix isn't working for me. Sample file attached.
Message 9 of 10
pendean
in reply to: jsmithAP3Q4
Thanks for sharing your file: please explain where/what each field's OBJECT is getting its data
Some of these appear to get info from somewhere, but where
Message 10 of 10
jsmithAP3Q4
in reply to: pendean
The column on the left contains the attribute definitions so the values may be updated after the block is inserted. The column on the right contains an mtext with a field entry that is linked to the value of the corresponding attribute definition (i.e. the field in the right column row 1 references the attribute definition for the left column row 1; rinse and repeat all the way up).
Some values that are being shown are the default values for some attributes, but if I change an attribute value after the block is inserted, no combination of fieldeval/regen/plot/etransmit gets the mtext field to update.
Forma Design Contest
AutoCAD Beta
