Dynamic Block - Equal scaling lines
vkulikajevas
vkulikajevas
I am trying to make Dynamic block, which Vertical line scales with Distance 2 only on X axis. (distance between the lines are always = (Distance2) / 3). Can you help me to make this block work? If I apply scale, it scales lines on Y axis to... which I do not need. Maybe there is a way to assign the dimension parametrically?
Attaching the Autocad file too.
h_s_walker
You just needed to add a couple of move actions to distance 2 and change the multipliers to 1/3 and 2/3. See the attached drawing.
Howard Walker
Left Handed and Proud
vinodkl
Here is the screencast of how you can do it.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
