Dynamic Block chaining and specific distances
I'm trying to create a dynamic block that will consist of 3 rectangles. The first rectangle is stretching to a list of values.  The other two rectangles should move when the 1st is stretching. But Should move to specific values and change the distance between them too.
What i have achieved until now is the other two rectangles to move when the 1st is stretched but i can't cahnge the distanced between them.
I'm attaching a sketch to give you an idea.
Do you know if this something that can be done with dynamic blocks.
Thank you
h_s_walker
This should help you on your way
Howard Walker
Left Handed and Proud
ojuris
or little bit different solution as previous
Thank you!!!!!
That is what i was looking for.
Cheers
