HELP : NOTHING SEEMS TO BE VISIBLE
Hi everyone,
I was making Dynamic blocks and when I was adding texts to this blocks suddenly my AutoCad file just shut down and after this nothing but the dynamic block was seen. When I open this file it says "This dwg contains authoring elements. Open in block editor?" when I say no I can only see my dynamic block but it is not a block anymore, when I say yes it opens my dynamic block in block editor but when I close block editor it closes the file.
All the layers are open.
When I command select all it selects more than just dynamic block but I can not see a single line.
I tried command RECOVERALL and command AUDIT and command ISAVEBAK and nothing happened.
When I tried command IMPORT it says "you have selected an unsupported DGN file. Only V7 and V8 DNG files are supported." (I use AutoCad 2012).
When I try to open the recover file it says "Drawing file is not valid."
I really do not know what to do now if anyone could help me I will be really appreciate it.
*EDİT:
I tried to change the ObjectARX settings and when I wrote OP in the command line it says "The following shortcuts in the plotter search were invalid and ignored."
rkmcswain
Grab your latest backup file, and next time do a QSAVE before jumping into the block editor.
This way if you crash, you can start over at the point before you got into the block editor.
Here is someone who had the same problem, for whatever that is worth. It's an unsolved bug.
https://forums.autodesk.com/t5/dynamic-blocks/drawing-disappeared-after-saving-it-in-block-editor-in...
R.K. McSwain     | CADpanacea | on twitter
Thank you, but like you said I saved before I open the block editor and start to work on it however this happened anyway.
Thanks again.
