Dynamic Block BOM
Dynamic Block BOM
eric
Dynamic Block BOM
eric
I have a set of Dynamic Blocks I have created to represent individual members of an assembly.  I group those members based on an attribute that all the different blocks/members use.  I currently use a data extraction table to create a bill of materials per assembly, but I was hoping to create some sort of block or table that I could pass the assembly number through to individualize the tables per assembly, rather than creating separate tables modifying the same table each time it needs to be filtered for a different assembly.
h_s_walker
Do you need to manually edit anything in the table?
If not, why don't you put the table in the block itself and then put the relevant field in the relevant cell?
Howard Walker
Left Handed and Proud
