Array Color+Value of an attribute in dynamic Block
Hello all,
im creating a seating plan based on a module with 4 seats. The requirements are the following
1.- to be able to change between steps or seating module
2.- to be able to color the individual seats on the first row and array the result
3.- to be able to XY Array the module.
1.- Solved this with a visibility state. OK
2.- I create an attribute for each seat. then, editing the attribute Properties, i can select a different layer so the attribute color changes.
3.- Array works fine except for the Attributes 😞
after checking for days, I´m certain now that, unfortunately, i will not be able to array the attributes. However, i though that maybe there was a way to create a text with an inserted field that retrieves the result from the attribute values for <Value+Layer Color> I tried using a formula by copying the expressions from autocad but it doesnt work. I read about Diesel Expressions but i cannot put together a string that works as i needed.
my goal is simple as the array that i need will be repeating the initial module color coding, nothing fancy there...
can anyone help me? Please.. 🙂
regards in advance!
