Create dynamic blocks using an excel list
Hi all,
is there a way how I can automatically generate dynamic blocks in autocad using an excel list? The blocks should be placed at the coordinates (e.g. 10, 13, 201) of the list containing the attriubutes e.g. TAG, WIDTH and HEIGHT.
Example given:
TAGWIDTHHEIGHTxyz
A12101010
B11102010
C12103010
D12104010
E21105010
I made a few scripts in the past months but this exceeds my knowledge. I would be really thankful if somebody could guide me how to do this.
Kind regards,
Robert
JBerns
@Anonymous,
Just to clarify,  when you say "create dynamic blocks" do you mean create the block definition or insert a dynamic block already defined?
If the latter, would you be able to share a drawing that contains your dynamic block?
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Create a block definition, the block could be just a circle (e.g. diameter 5) with the named attributes.
If there is no way to create one, then i can define blocks in advance.
Thanks for the help in advance!
Warm greetings,
Robert
JBerns
@Anonymous,
Does the block have to be a dynamic type? It becomes a bit more complicated to create a dynamic block programmatically.
If it can be a standard block, the X and Y scale can be adjusted to achieve the WIDTH and HEIGHT dimensions from the table.
Does the table have to be an Excel file? A CSV file, being text, is much easier to read as compared to an Excel file.
Here are other forum posts where users needed to insert blocks by reading data from Excel/CSV files.
     Lisp to insert blocks from csv or excel file - AutoLISP, Visual LISP & DCL - AutoCAD Forums
     Insert block, but reading from Excel - Autodesk Community - AutoCAD
     HELP......With Insert Block Lisp From Excel File
     Read CSV by Lee Mac
Let us know if you need more assistance to develop the code.
Jerry
CAD Administrator
Hi Jerry!
Thank you so much for the links! I actually managed to resolve my issue with an autocad script! Its not elegant but gets the work done!
The links you mentioned helped me alot! I will mark this answer as solution.
Robert
JBerns
Robert,
You are most welcome. Great to hear you have a solution. Glad to be of service.
Jerry
CAD Administrator
