Dynamic block blue triangle
kevyn_macalino
kevyn_macalino
Hi. How can I move the blue triangle (the one with the red circle) to the corner similar to the other blue triangle on the lower side?
Libbya
Post the block file, not a picture.
It's actually very simple.
1. Block Editor.
2. Click on the Parameter involved with the out of place arrow.
3. Click on the arrow and move it to where you want it to go.
Libbya
While it may be that simple, it probably isn't.  More likely is that the linear parameter needs to be added to the selection set of the stretch action that is associated with the other grip at the bottom of the block.  It's hard to tell until he posts the block, which is why I said to post the block.
Good point. Post the block
Emmsleys
Following up on your thread, it appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
