Refer to other attributes value while creat block_does not work
Hi, experts:
My problem is while I am creating a block with 4 attributes I already defined the first 3 attributes and for the 4th attributes I want it to be the combination of the 3s that I already created so I insert 3 fields which are the values of the first three attributes (actually they are texts in block editor);
when I insert the created block into drawing and input values for the first 3 attributes, for the 4th attributes I does not get what I want, actually there is only --------, the "sync" command under the block tab or the "update field" command do not work;
so what is the problem, if the method I employed is wrong?
thanks a lot
Libbya
Always post the block file.
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please post a sample file if you're still having an issue or post back with what worked for you.
Thanks.
Sarah Emmsley
Technical Support Specialist
