Dynamic block auto change the background color
smatchai_v
Message 1 of 12
smatchai_v
Have anyone ever run into this kind of dyn block issue?   Dynamic block auto change the background color from 255, 255, 255 (which we intend for a wipe out background) to be in green by itself.  Moreover the same block show different background color btween model and layout spaces too.  See enclosed images.  This made the block plot in black background.  Any fix available?  What'd cause it to act like this?  Is it a program bug?
Replies (11)
Message 2 of 12
imadHabash
Can you share with us a CAD dwg ample for testing?
Imad Habash
Message 3 of 12
smatchai_v
Here is the block that has the issue. Thanks for taking a look. Hope you
have a solution for this. Thank you.
Smatchai
Message 4 of 12
imadHabash
Nothing attached!!
Imad Habash
Message 5 of 12
smatchai_v
It is a small finish tag only. Not a full dwg file. Can you see only this
or you need to have the real dwg too?
Message 6 of 12
ojuris
try to use wipeout instead of background (I don't know what you use, maybe solid hatch)
Message 7 of 12
h_s_walker
@smatchai_v You only need to attach the block. See the image below for attaching a file
Howard Walker
Left Handed and Proud
Message 8 of 12
smatchai_v
We use wipeout before but it randomly keep acting weird sometime by changing order of the objects (above or under).  So we use the SOLID hatch in color 255, 255, 255 for the trick instead.   It work likes a charm up until the lately incident.
Message 9 of 12
smatchai_v
Here again is the dynamic finish block.  Not sure the attachment didn't get through before.  Hope it went thru this time.
Message 10 of 12
j.palmeL29YX
The hatch doesn't have the (true)color 255,255,255 as you wrote, but the index color 255. The last one changes its color (black/white) automatically depending on the background color, the true color will always look as white.
(view in My Videos)
Jürgen Palme
Message 11 of 12
smatchai_v
Thank you!  I will try testing it if that's the case here.  A small color setting could cause such a mess.
Message 12 of 12
j.palmeL29YX
@smatchai_v wrote:
... if that's the case here.
We only know what you have posted. Your file doesn't include a Dynamic Block. If my suggestion above doesn't help you should post the complete (dynamic?) block.
Jürgen Palme
