DYNAMIC BLOCK ATTRIBUTE PROBLEM
I HAVE A DYNAMIC BLOCK OF A BASE CABINET WITH ATTRIBUTES REPRESENTING THE HEIGHT WIDTH AND DEPTH IN THE BOTTOM LEFT CORNER. MY ISSUE IS WITH THE DEPTH ATTRIBUTE. IT HAS A LOOKUP ASSOCIATED WITH IT. I WOULD LIKE WHEN I BRING THE BLOCK IN FOR IT TO DEFAULT TO 23.25" BUT FOR SOME REASON IT DEFAULTS TO 15.25" WHICH IS IN THE LOOKUP TABLE ALSO BUT IS THE SMALLEST DIMENSION.
ANY HELP IS APPRECIATED.
THANKS,
Libbya
Do not post in all caps.  It's irritating and inconsiderate.
Always post the block when looking for assistance.
On insertion, the parameters are not modified by the lookup.  They are inserted in the as-drawn block definition values.  If you want it to insert at 23.25, then draw it at 23.25 in block editor.
