Variables and Simple Formulas
Message 1 of 11
Hello! I'm new to dynamic blocks and wanted to get some advice.
I'd like to set two variables within dynamic block (WIC and Frame Thickness) that a drafter can enter and have automatically calculated in the formulas displayed without having to open the block editor.
It doesn't seem like it should be too difficult, and the formulas are elementary. Also, note that some formulas are within dimension text strings.
Example:
    Input: WIC = 36
    Formula: "20 x (WIC + 1/8) ramp notch in floor panel"
    Output:  "20 x 36 1/8 ramp notch in floor panel"
Thanks in advance!
Replies (10)
Message 2 of 11
Here is the block...
Message 3 of 11
Libbya
For formulas, easiest is probably to use user parameters and define whatever formula you like.
Message 4 of 11
I know how to add a formula. I just don't understand how to reference a variable in a formula.
If I define an attribute named "WIC", how do I reference that within the formula?
Message 5 of 11
Within your formula text box, you would need to just enter another field linking to the object's value (WIC's value).
Message 6 of 11
Libbya
Did you actually try that?  I have not found that formula fields referencing values housed by attributes will actually update even if the 'display value for block reference' is checked.  I have found that formula fields referencing values housed by user parameters will update, though, which is why I recommended them.  Use the blockplaceholder fields for the user parameter values within the formula and it works a treat.  Edit the user parameter value in properties.
Message 7 of 11
Yeah, it seems that solution requires you to manually update it - which is silly.
I'll look into what you said and get back to you!
Message 8 of 11
I've created user parameters, but can't figure out how to reference them in the formula field. I've messed with this for the past few hours and I've gotten no where. Can anyone give me a step-by-step? I feel like this should be extremely easy, but I can't figure it out.
Message 9 of 11
Also note that I don't actually want the dimensions of the drawing to change - just the text within the block.
Message 10 of 11
Libbya
Here's a simple test block screencast that shows how to add a user parameter and place it in a formula field along with a linear parameter value.
Message 11 of 11
MMcCall402
I introduce the user input into a dynamic block thru User Parameters and display the output thru Attributes.  The Attributes have text and fields with formulas for the numeric values as their default attributes. The formulas in the fields use fields to gather values from things like user parameters, dynamic parameters and drawing objects.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
