Dynamic block array problem
hi
my question is i have a  block how to do array action with scale. scale is 300mm, 400mm....etc my block is cable tray.
i have problem in dynamic block.i don't know how to make array action with scale. when i make its only applying first scale(300mm) object rest of the scale does not appear. indeed i don't know.  could anyone help me. i would be appreciate .
best regards
hussain
TheCADnoob
could you share the block so that we could take a look at it?
CADnoob
ok i will share now. pls check as i mentioned in the post. that block
included 4 types.plain ladder as name of 4th types in block.i also showed
visibility.my problem i am applying scale for this block. i can
stretch(plain ladder) but i unable to make array action with scale.
i have 150mm to 800mm cable ladder. when i finish everything after the
scale is appearing only 150mm rest of the does not appearing.
i hope you will consider my problem .
best regards
thajmul hussain
